Support thread for FullFixbySamik paid version - Sam!k - 09-22-2024
If you have purchased FullFixbySamik paid version and have some problem, write all your problem and questions here.
Don't write that in selling section, because as sad
fantomel, it's selling section and not support.
Different between free and not free vertions:
1. Xentry and Daimler Truck working with SDConnect.
2. Easy Installation of DTS Monaco 9.
3. Xentry, Daimler Truck and WIS 07.2021 automatic activation.
4. ZenZefi After-Sales_STANDARD certificates, for diagnostic new models.
5. "Actuations" tab for trucks, in Xentry and Daimler Truck.
6. Xentry OpenShell 2025 working with Enet cable (with new DoIP models).
Key is for one system!
It's not for laptop, not for windows, not for Xentry and not for windows!
It means after formatting system, after changing some hardware, after connecting, disconnecting any adapters it can be accepted and can not be accepted,  if it's not, need to buy new one.
About fix, payment information you can read in selling section thread of FullFixbySamik last version.
FAQ
Can't do it yourself?
If you're not confident in doing this yourself, simply order the "Remote configuration" option and we'll do it for you remotely.
Is antivirus interfering with the program?
Microsoft Defender is fine. If you use a third-party antivirus, temporarily uninstall it during installation and activation.
The program says “No internet” or “Incorrect activation key”
The program requires an active internet connection to our server. If your network blocks the connection, try a different network or a VPN.
I installed FullFix but can’t find the Toolkit
If the main program is a new version and without SDConnect support, look for SDC4-VCI Switcher on the desktop.
This tool requires an internet connection to validate activation.
Run it and select the SDConnect mode.
If you have multiple adapters, better use only one. If your system HWID changes, SDC4-VCI Switcher will no longer work.
Which IP address should I use for SDConnect?
For SDConnect use the range 172.29.127.xxx
The xxx part can be any number from 1–254, except 129.
Example: 172.29.127.127
For DoIP with SDConnect add an additional IP: 169.254.0.35
I select SDConnect mode, config IP and it still didn't working
Switch to VCI mode, enable filewall, reset firewall settings to default, switch to SDConnect mode, allow connection when firwall ask, work.
If still Toolkit didn't see SDConnect, then check:
Ethernet adapter, driver.
LAN cable.
SDConnect.
Power in SDConnect.
SDConnect didn't working with DAS via Wi-FI?
Read this.
The Xentry is not activated
If you already run FullFix and still see a “not activated” message, check that Secure Boot is disabled and run FullFix again with only the first (activation) component selected.
DTS Monaco freezes when i paste the activation code
If DTS Monaco freezes when you paste activation code, then just write it manually. Usually it's happening on Windows 11.
After addon update on 2026 version, Xentry doesn't running and i see error 2221-1?
Read this post.
RE: Support thread for FullFixbySamik payed version - BreakDrop - 09-22-2024
(08-08-2023, 02:21 PM)samo733792 Wrote:
Instructions for Xentry activation
Xentry activation never was so easy:
1. You have to install Xentry, restart PC.
2. Install FullFixBySamik (by checked Activate Xentry)
3. Activate Xentry in Config Assist (shortcut for Xentry Advanced Keygen on desktop)
4. Start Xentry from desktop icon. Leave login and password field blank! No need to write anythink.
It is done!
Hi.
@samo733792, please!
Please include a hint in the description or in the .txt file to solve the SDconnect C4 connection problem.
I spent a lot of time looking for a solution to the SDconnect C4 connection problem and the message "Unknown Toolkit COM Server Error. (801)".
I spent a lot of time reinstalling Windows and reinstalling Xentry and FullPatch by Samik.
Here's what you need to do:
1. Set a fixed IP address for the LAN connection:
   IPv4 assignment: 172.29.127.221
   IPv4 subnet prefix length: 24 (for Win10), or IPv4 subnet mask: 255.255.255.0 (for Win11)
   IPv4 gateway: 172.29.127.220
2. Go to SDconnect Toolkit=>Software update and update/upload four files firmware (many video's about that).
3. Test with SDconnect Tools => Self-diagnosis.
After that my problems with SDconnect C4 ended!
Xentry, DAS and HHT work!
If you put these tips in the description, you will save a lot of people a lot of time.
RE: Support thread for FullFixbySamik payed version - spider93 - 09-29-2024
(09-22-2024, 10:37 PM)samo733792 Wrote: If you have purchased FullFixbySamik payed version and have some problem, write all your problem and questions here.
Hello samo thanks for your help
I just setup Daimler truck 10.2024 and then applied full fix specially fix sd connect cause I need to use it with C4
But the configure Assit still have only vci option and I can not choose sdconnect
Please help how to fix to use Daimler truck with sdconnect C4
RE: Support thread for FullFixbySamik payed version - Sam!k - 09-29-2024
(09-29-2024, 03:30 AM)spider93 Wrote: Hello samo thanks for your help
I didn't check 10.2024 yet. Bu5 good that you installed it.
In Daimler Truck, in ConfigAssist need to select Simulation mode!
After selecting Simulation mode, Toolkit have to start and work.
RE: Support thread for FullFixbySamik payed version - mickal1313 - 10-01-2024
hi Samik
what exacly is a diffrent between free version 4.5 and  version we have to pay £20 ?
RE: Support thread for FullFixbySamik payed version - Sam!k - 10-01-2024
(10-01-2024, 12:18 AM)mickal1313 Wrote: hi Samik
I can copy description from both versions here but i think easier to read there.
I add it to first post.
RE: Support thread for FullFixbySamik payed version - NewDriver - 10-11-2024
Hi Samik,
I installed Xentry 2024.06 and configured IP 169.254.0.45/255.255.0.0 for C4DOIP but xentry failed to communicate.
Was tried to ConfigAsisst but SDconnectToolKit said "No equipment accessories"
Xentry shown this error.
“Communication error. You have to connect an MVCI device before reading ignition or batter voltage.
Initialization of the multiplexer has failed.
Possible causes and remedies”
Please advise me how to solve. Thank you again..
RE: Support thread for FullFixbySamik payed version - Sam!k - 10-11-2024
(10-11-2024, 06:06 AM)NewDriver Wrote: Hi Samik,
You config only DoIP IP?
Which car you need to connect with this configs?
