  • 13 Vote(s) - 2.54 Average
Support thread for FullFixbySamik paid version
505
Hi. Everything was working good I tried working on W206 with xentry all good but after I used DAS on a W203 and then tried to open xentry it doesn’t open and gives error [2221-1] XENTRY could not be started. What could be the issue?
(09-21-2026, 05:13 PM)Rabih AMG Wrote: Hi. Everything was working good I tried working on W206 with xentry all good but after I used DAS on a W203 and then tried to open xentry it doesn’t open and gives error [2221-1] XENTRY could not be started. What could be the issue?
There was something else!
Just after running DAS can't be such problem.
Nothing at all. What should I do next?
Ur Add-On Updates is running !
- run Add-On Blocker >>> Block
- reRun Fix again
All Done
Services:
- MB SW,Trucks,Cars
- Smart SK
- Ved_DTS Cod
- EGR, SCR, DPF & Adblue OFF
- EPC On/Off line (Cars,Trucks)
- AutoVEI, DIMSport, Jaltest,VCX,C4,EngineDance,ECUmaster
(09-21-2026, 06:08 PM)Rabih AMG Wrote: Nothing at all. What should I do next?
Maybe in error message, there's something else, some file, for example?
Make a screenshot.
Make a screenshot.
after the addon update 06/2026
error
[2221-1] ...... xentry\bin\GlobalEnvSettings_PROD.properties
PLEAS "thanks" [Image: thanks.jpg] and "reputation" [Image: rate.jpg]
Make a screenshot.
error
Restore original file, then run fix again and select only activate Xentry option.
.zip
GlobalEnvSettings_PROD.zip
18
1.7 KB
Thanks given by: luki03 , paradise_garage , zipoman2011
512
Thank you! Now it works ok. But ignition does not read automatically only manually is that normal?
(09-22-2026, 09:22 PM)Rabih AMG Wrote: Thank you! Now it works ok. But ignition does not read automatically only manually is that normal?
It's depends from adapter and car.
Users browsing this thread: 3 Guest(s)
