  • 29 Vote(s) - 3.03 Average
Transponder Programming
Hi guys, I programmed a transponder key to a Zafira using my tech2. It asked me to get approval from Tis before proceeding which i did and it then said... "enabled security access type 3". Then it worked.
My question is, Do i now have to do this each time i carry out procedures on security systems or is that now enabled for good?
Many thanks in advanced
Barrett130
(05-22-2011, 02:03 AM)barrett130 Wrote: Hi guys, I programmed a transponder key to a Zafira using my tech2. It asked me to get approval from Tis before proceeding which i did and it then said... "enabled security access type 3". Then it worked.
Barrett130
In your Tech2 & in your PCMCIA Card, now you have "Stored" 2 more attempts for ANY Security Job that you will make! Wink
And YES after 3 using attempts you need to make again the SAME Procedure! Listen
GM "Rules" my friend! Smile
Best Regards! Cheer2
Thanks given by: barrett130
old topic but (maybe) interesting info:
Buy an op-com/opel scanner. They are quite cheap (opel scanner is ~400 EUR) and they allow normal programming (activation/deactivation of features, reset/install of electronic modules, sensors calibration, transponder programming) without the Tech2 restrictions (getting TIS approval). You will need a computer/laptop (these interfaces are not standalone, like Tech2) but you get certain advantages....
Opel
05-11-2025, 11:23 PM
07-11-2022, 12:08 AM
04-15-2020, 04:13 PM
