  • 31 Vote(s) - 3.23 Average
opel corsa c / Transponder key learning failed
Hi
Can someone pls help me. I have an opel corsa c utility 1.4i. all keys lost. Customer took vehicle to dealership & was told ecu kit needs to be replaced. towed car to me as i run a keys service in my workshop. bought 2 blank keys with transponder. Tried to program keys with op com. programmes successfully & and shows wrong transponder key status & key learning failed. Diagnosed the vehicle with op com. ECU: p1614 wrong transponder key/p1614 immobiliser wrong signal recieved. BCM:b3061 wrong transponder key/b3055 transponder key problem/b3060 unknown transponder.
found an immobiliser checking pdf online & no wiring problems detected. Also the immobiliser ring coil on ignition had an issue with 2 wires goin to ring. resoldered them. Car with spanner flashes & car will not start. please help.
Ciao
(06-09-2015, 09:37 PM)maseiti Wrote: Hi
Ciao
hi
which year? which transponder you use?
roki
best regards
Did you buy already prepared transponder for Opel, I suppose that is ID40 Opel crypt? Or you buy blank PCF7935, which need to be prepared for programming on car?
If I help you, please put reputation Tup
Thanks given by: maseiti
Hi How may keys are all ready programmed to the car.regards Mke
Ciao
hi
roki
best regards
year model 2005. transponder type:pcf7935AS ON 1 SIDE, OC ON 1 SIDE. had to of those which programs successful. only transponder status on op com show wrong TP. tried another transponder pcf7935AS, fails to recognize it. got from a friend of mine & said it was blank.
only 1 key was programmed to the car. i also programmed 1. all shows wrong transponder key on transponder status
Ciao
I dont think the problem is with the key ----there is a vin or something else wrong in one or more of the units like BCM or cluster or ECU and then it wont accept the key.Just go through all of them and double check
hi
roki
best regards
:devu
in immobilizer measuring blocks doe any of the keys show up as a number ?
if yes then that key is programmed to immobilizer
can you reset bcm and instruments ?
i have no 1 & 2 programmed. yes it shows as programmed to immobiliser but on transponder status shows wrong TP. i can rest BCM. i cant go into instrument.
As I already say, those chips are BLANK, you must prepare both chip, because same model of chip is suitable for many, many cars...but must be crypted for Opel cars if you want to use it on Opel...you just go to someone who own ZedBull or something similar and prepare it like OPEL ID40 CRYPTO, and I suppose they will work it without coding again!
Thanks given by: maseiti , Ashraf6119 , Strikers
06-12-2026, 06:27 PM
Opel
05-30-2026, 08:29 PM
