maseiti
Location OfflineJunior Member
Thanks Given: 14
Thanks Received: 2 (1 Posts)
19
thanks for all your responses, will try your suggestions when i get to workshop today
Levon
40
Thanks Given: 47
Thanks Received: 132 (18 Posts)
49
16
Hi, tell me year of your car
maseiti
Thanks Given: 14
19
opel corsa c utility 1.4i, 2004.
maseiti
Thanks Given: 14
19
Hi KRISM.
i have reset bcm, engine ecu. i cannot reset instruments. error: turn ignition on,error communicating with ecu or ecu busy or rejects request. also getting this DTC:
P1614 - Immobiliser Wrong Signal Received
(04) - Present
P0120 - Throttle Position Sensor 1 Voltage Low
(02) - Not present
P1614 - Wrong Transponder Key
(00) - Not present
tried diagnosing with my autel. intruments no faults/ bcm: no remote keys programmed. I am not programming remote keys.
please help
maseiti
Thanks Given: 14
19
i have to agree with you, bcause i got an id40 transponder ready for opel, programmed it successfully and still same problem. cannot connect to instruments. will that require another cluster or is there another solution?
