(03-14-2014, 01:16 AM)mercedessd Wrote: fix is to reinstall Flash files from install DVD. found in folder stardiag\SDFlash_Setup
error seemed to return after reboot, i set the PKW folder and all contents as read only, so far so good.
Since this thread was originally about the error "it was not possible to find path '<HDD installDir> profi_cd.ini' " I finally found a valid fix. today after I got the error I noticed there was an option to view a log, when I viewed the log I saw what was causing the error.
so basically It was looking for a folder that was not there. it wanted to see the profi_cd.ini in a folder on the C: drive at the following location.
C:\star\SDflash\Release\PKW\profi_cd.ini
I basically copied all the files from the SDflash folder from F
rogramme Once they were copied I tried to scn the 722.9 transmission again. it failed, was looking for another folder called cff, which it wanted at the following address, C:star\XentryDiagnostics\var\temp\Xentry\cff
I created the folder at the specified location. rebooted computer and tried to scn again. this time it worked perfectly, no errors!
followup.
so after poking around and Rociante sending me some of his logs i found the issue was in the flash.ini located at F:\Programme\DAS\bin\Flashen it was set to this.
[Directory]
PKW=C:\star\SDflash\Release\PKW
smart=C:\star\SDflash\Release\smart
LKW=C:\star\SDflash\Release\LKW
Transp=C:\star\SDflash\Release\Transp
Unimog=C:\star\SDflash\Release\Unimog
FUSO=C:\star\SDflash\Release\FUSO
BharatBenz=C:\star\SDflash\Release\BharatBenz
FLASHDATAREGIO=C:\star\SDflash\Release\Flashdataregio
FBV=C:\Star\XentryDiagnostics\var\temp\Xentry\cff
insted of this
[Directory]
PKW=F:\Programme\SDflash\Release\PKW
LKW=F:\Programme\SDflash\Release\LKW
Transp=F:\Programme\SDflash\Release\Transp
smart=F:\Programme\SDflash\Release\SMART
Unimog=F:\Programme\SDflash\Release\UNIMOG
FUSO=F:\Programme\SDflash\Release\FUSO
BharatBenz=F:\Programme\SDflash\Release\BharatBenz
FLASHDATAREGIO=F:\ProgramData\FlashdataRegio
FBV=E:\ProgramData\data\Xentry\Flashfiles
notice the bottom entry?
not sure how an older flash.ini was introduced to my files, but i think that is what happened.
