xentry 01.2014
While attempting to code a 722.9 module today i encountered this error.
"it was not possible to find path '<HDD installDir> profi_cd.ini'
202-01-2014, 04:44 AM (This post was last modified: 02-01-2014, 04:45 AM by Adam0773.)
Can not perform offline PROGRAMMING transmision 722.
Online only plus SCN coding must be perform ( also SCN coding must be perform for engine ) together
302-01-2014, 05:34 AM (This post was last modified: 02-01-2014, 05:41 AM by mercedessd.)
(02-01-2014, 04:44 AM)Adam0773 Wrote: Can not perform offline PROGRAMMING transmision 722.
I am not trying offline, this is an online attempt with valid login, will also politely disagree with having to code the ME as well.
Hi friend.. You have solved that problem? I have some error... My xentry 2014 version update with addons have proficd file different of the xentry 2014 basic installation.. Now i replace the file and i try to update the ECU gear with scn..
I have personally done programing and SCN coding on 722.9 with 01.2013 Xentry OFFline(had no access to server).Programming been done with 03.2012,but SCN with 01.2013---hard but possible.So,probably software error(SDFlash files).
