  • 36 Vote(s) - 3.11 Average
Unusual Error while SCN coding
xentry 01.2014
While attempting to code a 722.9 module today i encountered this error.
"it was not possible to find path '<HDD installDir> profi_cd.ini'
any advice will be greatly appreciated
Thanks given by: naseem__amg
Can not perform offline PROGRAMMING transmision 722.
Online only plus SCN coding must be perform ​​( also SCN coding must be perform for engine ) together
(02-01-2014, 04:44 AM)Adam0773 Wrote: Can not perform offline PROGRAMMING transmision 722.
I am not trying offline, this is an online attempt with valid login, will also politely disagree with having to code the ME as well.
Thanks given by: Rocinante
Have you installed all the online updates??
As far as updating the M.E., its not necessary, but it is recommended to update the software and recode it as well..
Thanks given by: ToMiBoY , webmaster , avandgarde , JarsaR
fix is to reinstall Flash files from install DVD. found in folder stardiag\SDFlash_Setup
Hi friend.. You have solved that problem? I have some error... My xentry 2014 version update with addons have proficd file different of the xentry 2014 basic installation.. Now i replace the file and i try to update the ECU gear with scn..
I have personally done programing and SCN coding on 722.9 with 01.2013 Xentry OFFline(had no access to server).Programming been done with 03.2012,but SCN with 01.2013---hard but possible.So,probably software error(SDFlash files).
That problem only with xentry 2014..
probably its a limitation or a bug only with the new xentry
but just to make sure will reinstall flash files as suggested earlier
