VIIPlusLoader v08.025.13 (29/10/2025) +
VCDS 25.3.2 Release - 25.10 (beta)
Thanks + Reputation (Rate +1) = Password
VIIPlus Loader : is essential software for using the VCDS diagnostic system with HEX-V2 cables. It enables and manages diagnostics for VAG group vehicles (Volkswagen, Audi, Skoda, Seat)
Main features:
&- VCDS Activation: Launches and updates the VCDS software while ensuring compatibility with the HEX-V2 cable for a complete diagnostic experience.
&- Firmware updates: Automatically updates the diagnostic cable firmware upon first connection to ensure maximum compatibility with the vehicle.
&- Advanced diagnostics: Allows access to advanced coding and adaptation options for vehicle electronic systems.
&- Multilingual support: The loader supports multiple languages for simplified international use.
VCDS :
VAG COM or VCDS (VAG COM Diagnostic System) is an ultra-fast diagnostic tool exclusively for VAG group brands (VW, Audi, Seat, Skoda, and Bentley). It can also be used as an EOBD/OBDII tester. Compared to VAS brand testers (ODIS), this interface performs essentially the same functions, except for key coding and service programming of control units.
VCDS FUNCTIONS
-Read and clear error codes from all electronic systems
-Reset a maintenance interval and manage variable maintenance intervals yourself
-Actuator testing
-Retrieving measurement values and modifying basic settings
-Dynamic adjustment of the injection timing of the rotary diesel pump
-Data recording that you can display graphically
-View the control unit information
-Common Rail Injector Coding
-DPF Regeneration
-Programming a hitch device
-Calibration of components such as throttle bodies, steering angle, xenon headlights,...
-Replacing the rear brakes on vehicles equipped with an electric parking brake
Main features:
VCDS :
VCDS FUNCTIONS
-Actuator testing
-DPF Regeneration
Thanks given by: mickal1313 , pely86 , Paco230 , davinci_86 , ecudiesel , kamaleon , mayong , camcone , tocov , dtbmw1 , Galee , jomue , Xfiles_de , A21b , cataiordache , zlatomir , eddydexter , zanotech , churchy44 , pacomasi , tcruz , AN1S , TytuS , Czater , red patrol , amaflo , Piston73 , yuvament , integral90 , Benek107 , cryptkrank , pakojoco , Oleg777 , vr677 , m550 , bob90-6 , 4545 , mysterynight , ASTRASAT , bmotor60 , itssvinh , Davido , joca 3 , andrei puzderie , kaya1923 , Meck01 , Diegone , Schorsch94 , atomiczen , Toku852ae , Tuning , zacocity , cruiserman , sashy787 , pirotess66 , Alex2389 , MacManiac78 , Mister_ACE , Bjunest , aanoys , clzhexer , robyro , DSO13 , Serrano9903 , darkchild972 , Xonorik.79 , DWMECHV , morti83 , tanjawinkler.joh , donidarco , Flinta92 , jakim8 , mzg , Red_Ned , hidaeraldo , Tony289 , Neilos888 , Marcusp , samircz , wolfpapp , soluzioni , swappenheimer , Erko , Northus , paterskipawel , luckysd , Almoska1989 , Ernesto ♠︎Joker♣︎ , ANONIM , Fonika13
