  • 15 Vote(s) - 2.8 Average
VVDI MB Tool
These are units that have worked with the mbtool vvdi.
I'm having issues with 2 others
I have done a W204 on the bench (worked)
I have done a W203 via IR Read password (worked)
I am having issues with a W211 reading password via IR it states "This EIS does not support Password via IR"..what do you recommend?
Also having issues with a W221 chassis with a W216 EIS.
I removed the EIS and tried password calculation on the bench with under W221 it read the data & asked me to remove and reinsert IR over 100x to reach 100% of the password calculation with no success.
Any suggestions??
Thanks in advance.
Hello mate,
VVDI MB on W211 Mostly not get password.
If u have Key with Version 51 or 57, then simply read from it.
If all key lost, Rosfar will read the full data with password and then u calculate keys by VVDI.
Regarding W221, Reading Password for all Key lost is not supported yet.
Add support for lost all key W216 2009- but the EIS number must be 216, NOT 221.
Best regards.
[Image: mhhsig.gif]
(02-22-2017, 11:27 AM)webmaster Wrote: Hello mate,
Best regards.
Thank you for the quick reply!!
Regarding the rosfar do you have or know the correct connections to read in circuit?
In r270 software you have all info what you need.
It just makes me feel good Thankyou
Thanks given by: Skazi954
