42
Thanks Given: 248
Thanks Received: 198 (87 Posts)
173
21
09-22-2016, 11:32 PM
(This post was last modified: 09-22-2016, 11:38 PM by IGNASIO88 .)
ME97 connected to - data read from ECU, did not try to reset. Check the scheme of connection.
Thumbnail(s)
Thanks Given: 66
Thanks Received: 41 (32 Posts)
345
112
This is going through the OBD connector correct?
Not sure what I'm doing wrong, just double checked connections at ECU and done them manually
42
Thanks Given: 248
173
21
the first time I connected the cable from the "VGS CABLE" CANH + CANL + GND + 12V power to take the car battery (some power supplies, do not support power)
18
Thanks Given: 592
Thanks Received: 176 (109 Posts)
328
48
I also having problem with the ecu adapters. I am using my old cable it works fine
18
Thanks Given: 592
328
48
From we're u buy adapter s
397
Thanks Given: 4687
Thanks Received: 1897 (598 Posts)
1,354
96
You need 120ohm resistor on the CAN. It is a high speed CAN and requires at least one resistor, 2 ideally.
