VVDI MB can't connect to ECU - Printable Version
+---- Thread: VVDI MB can't connect to ECU (/Thread-VVDI-MB-can-t-connect-to-ECU)
VVDI MB can't connect to ECU - BigK - 09-22-2016
Has anyone connected to ME 9.7 with VVDI BGA on the bench?
I have everything connected, but not sure what I am missing[attachment=146136]
RE: VVDI MB can't connect to ECU - IGNASIO88 - 09-22-2016
ME97 connected to - data read from ECU, did not try to reset. Check the scheme of connection.
RE: VVDI MB can't connect to ECU - BigK - 09-23-2016
This is going through the OBD connector correct?
Not sure what I'm doing wrong, just double checked connections at ECU and done them manually
RE: VVDI MB can't connect to ECU - IGNASIO88 - 09-23-2016
the first time I connected the cable from the "VGS CABLE" CANH + CANL + GND + 12V power to take the car battery (some power supplies, do not support power)
I tried two different power supplies, one is very heavy duty, and also just tried with car battery....
Nothing Sad
RE: VVDI MB can't connect to ECU - craig coopen - 09-23-2016
I also having problem with the ecu adapters. I am using my old cable it works fine
From we're u buy adapter s
RE: VVDI MB can't connect to ECU - bawarek - 09-23-2016
You need 120ohm resistor on the CAN. It is a high speed CAN and requires at least one resistor, 2 ideally.
RE: VVDI MB can't connect to ECU - craig coopen - 09-24-2016
It has 120ohms.
