  • 23 Vote(s) - 2.61 Average
Vediamo connection problem (need HELP)
Hello
I have installed Vediamo and i have the following problem
as it is in the picture attached.
On main vediamo menu i am able to recognize my sd connect by pressing Update button (recognition of SD connect with serial number is ok)
Later on Vecoute when i am trying to communicate with any ECU i get the following error :
SEE PICTURES
SDConnect C4 with 2015.09 DAS,Xentry
have anyone a idea?? THNX
really no one has an idea? or you do not want to help me!
Sad
(12-27-2015, 08:05 PM)beligold Wrote: really no one has an idea? or you do not want to help me!
Sad
Sdconnect SW HW versions may be need update to 2.3 and 2.8
Thanks given by: beligold , Dollsburg
Sad
thank you Big GrinBig Grin it works now
Hallo everybody i have a question.
Works vediamo 4.. with c4 wlan??
My vediamo 5.. don´t work with kline!!
What is the problem???
thnx...Beli
Vediamo5 was supposed for CAN-UDS communication. C4 works in PART-P mode on Vediamo5. So no K-Line supported.
WLAN is no Problem, if your Multiplexer is correct configured .
Use PART-W in Vediamo4 and K-Line will works.
BR
Thanks given by: daxxer
Whenever I want to use Vediamo on W203, I find it possible with Vediamo Ver4 and C3(partD) without PIC mod!
C4 is a multi-protocol tool yes but you must really know how to manipulate and maneuver with the firmware, and settings in vediamo .ini and configurator
“We, the unwilling, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, for so long, with so little, we are now qualified to do anything with nothing.”
