Vediamo connection problem (need HELP) - Printable Version
+---- Thread: Vediamo connection problem (need HELP) (/Thread-Vediamo-connection-problem-need-HELP)
Vediamo connection problem (need HELP) - beligold - 12-26-2015
Hello
I have installed Vediamo and i have the following problem
as it is in the picture attached.
On main vediamo menu i am able to recognize my sd connect by pressing Update button (recognition of SD connect with serial number is ok)
Later on Vecoute when i am trying to communicate with any ECU i get the following error :
SEE PICTURES
SDConnect C4 with 2015.09 DAS,Xentry
have anyone a idea?? THNX
RE: Vediamo connection problem (need HELP) - beligold - 12-27-2015
really no one has an idea? or you do not want to help me!
Sad
RE: Vediamo connection problem (need HELP) - motog123 - 12-27-2015
(12-27-2015, 08:05 PM)beligold Wrote: really no one has an idea? or you do not want to help me!
Sad
Sdconnect SW HW versions may be need update to 2.3 and 2.8
RE: Vediamo connection problem (need HELP) - beligold - 12-29-2015
Sad
thank you Big GrinBig Grin it works now
RE: Vediamo connection problem (need HELP) - beligold - 11-05-2016
Hallo everybody i have a question.
Works vediamo 4.. with c4 wlan??
My vediamo 5.. don“t work with kline!!
What is the problem???
thnx...Beli
RE: Vediamo connection problem (need HELP) - Hennich1983 - 11-05-2016
Vediamo5 was supposed for CAN-UDS communication. C4 works in PART-P mode on Vediamo5. So no K-Line supported.
WLAN is no Problem, if your Multiplexer is correct configured .
Use PART-W in Vediamo4 and K-Line will works.
BR
RE: Vediamo connection problem (need HELP) - Dollsburg - 12-14-2016
Whenever I want to use Vediamo on W203, I find it possible with Vediamo Ver4 and C3(partD) without PIC mod!
C4 is a multi-protocol tool yes but you must really know how to manipulate and maneuver with the firmware, and settings in vediamo .ini and configurator
