Vw crafter delphi dcm6.2V
[font="MHH Font", Calibri, sans-serif]Hello my friends,[/font]
[font="MHH Font", Calibri, sans-serif]Normally I‘m the guy who helpd others but today I need some expertise. [/font]
[font="MHH Font", Calibri, sans-serif]I have VW crafter 2,0TDi 2018 140hp sw-code 9970 tested also with 9808 with ad blue problem. With All my mod files Car won‘t start after exactly 50km range when I do ad off. No error message no fault code, and no info in instrument cluster. Tried with minimum 10 different solutions. I tried also to reset all and disconnect but no way, problems comes up again and again.  I haven‘t seen this even before on a car, but the delphi dcm 6.2 is still my biggest issue now. In past I have done many of them without any problems.
I tried also to reset and connect the ad pump with my solution but still same problem always. When I erase DTC without fault code car starts normal for next 50km. Also see after writing mod file ad blue range ——- in cluster.
[/font]
Here are the files: project is mod file:
[font="MHH Font", Calibri, sans-serif]https://mega.nz/file/dDhBiK4b#LRvh4n7smN...5VSsKcDGxc[/font]
[attachment=677030]
File Service
Stage 1 - 3 , MANUAL DPF , EGR , Adblue, DTC
Authorized Magicmotosport, Autotuner, Alientech, EVC Distributor
[attachment=677034]
Revolutionary AI automatic processing program with insane conversion rate : Tuning , Adblue, DPF , EGR , CAT , OPF, SWIRL , DTC...  ecu-ai.com
Yesterday, 12:27 PM
06-14-2026, 02:23 AM
06-11-2026, 07:58 PM
