1,545
Thanks Given: 834
Thanks Received: 3312 (599 Posts)
1,500
108
12-02-2016, 08:15 PM
Guys, I had my w140 cluster repaired by BBA reman. When it came back, we noticed no check engine light.
We didn't pay attention where it was on the cluster, if it worked at all.
My cluster shows no CEL on the strip for a bulb to come through. The vehicle's harness has no pin that sends power to where the CEL should be.
Did some W140's come with no check engine light??
340
Thanks Given: 119
Thanks Received: 2494 (1232 Posts)
2,415
18
Most w140 had no Check engine light
- SW Seed\key VGS\MED\IC virgin\hard coding Carplay HU5s1 HU5es2 any fw
- HW Genuine XentryConnect-SDConnect-eCom sale\repair\parts\setu
453
Thanks Given: 444
Thanks Received: 1578 (376 Posts)
670
57
12-03-2016, 01:42 PM
(This post was last modified: 12-03-2016, 01:57 PM by efka.)
Hold it
right there Anturage. As far as for EASatlanta judging by his name he must be out of Atlanta , Georgia that is USA. in that case his car is OBD2 compliant and CEL is mandatory since 1996. Unless its 1995 or older .The car WILL NEVER PASS MANDATORY EMISSION TEST without it. Problem must be that they used euro board for his cluster.
Hope I helped.
1,545
Thanks Given: 834
1,500
108
(12-03-2016, 01:42 PM)efka Wrote: Hold it
Hope I helped.
Car is 1993 thanks a lot guys!
453
Thanks Given: 444
670
57
In that case you are all good!
