W140 Cluster problem - Printable Version
+---- Thread: W140 Cluster problem (/Thread-W140-Cluster-problem)
W140 Cluster problem - EASatlanta - 12-02-2016
Guys, I had my w140 cluster repaired by BBA reman. When it came back, we noticed no check engine light.
We didn't pay attention where it was on the cluster, if it worked at all.
My cluster shows no CEL on the strip for a bulb to come through. The vehicle's harness has no pin that sends power to where the CEL should be.
Did some W140's come with no check engine light??
RE: W140 Cluster problem - Anturage - 12-02-2016
Most w140 had no Check engine light
RE: W140 Cluster problem - efka - 12-03-2016
Hold it
right there Anturage. As far as for EASatlanta judging by his name he must be out of Atlanta , Georgia that is USA. in that case his car is OBD2 compliant and CEL is mandatory since 1996. Unless its 1995 or older .The car WILL NEVER PASS MANDATORY EMISSION TEST without it. Problem must be that they used euro board for his cluster.
Hope I helped.
W140 Cluster problem - EASatlanta - 12-03-2016
(12-03-2016, 01:42 PM)efka Wrote: Hold it
Hope I helped.
Car is 1993 thanks a lot guys!
Sent from my iPhone using Tapatalk
In that case you are all good!
