  • 12 Vote(s) - 2.92 Average
W203 airbag module coding
Hi!! I would like to make coding (vin, etc) replaced module, so I tried to unlock module in developer mode (FN_SG_Entriegeln), then I got "security access denied - security access requested". Xentry 09/2015 (c3 mux). Anybody know why?
REVERSE ENGINEERING | SOFTWARE ENGINEER
try to go to control unit adaptation,then special setting then control unit release,then start with initial startup
you must first do reset the control unit, and then unlock it, still possible to get out and go back to the control unit ... Also you can unlock using menu special setting (if there is a password for it) ...
