W203 airbag module coding - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: W203 airbag module coding (/Thread-W203-airbag-module-coding) |
W203 airbag module coding - fabek - 12-16-2016 Hi!! I would like to make coding (vin, etc) replaced module, so I tried to unlock module in developer mode (FN_SG_Entriegeln), then I got "security access denied - security access requested". Xentry 09/2015 (c3 mux). Anybody know why? RE: W203 airbag module coding - ivannzowa - 12-16-2016 try to go to control unit adaptation,then special setting then control unit release,then start with initial startup RE: W203 airbag module coding - alex1972 - 12-16-2016 you must first do reset the control unit, and then unlock it, still possible to get out and go back to the control unit ... Also you can unlock using menu special setting (if there is a password for it) ... |
