Hehe, It is very nice that people are interested.
Well since this is a hobby for me time does not matter, money thought is very limited, that is why acquiring devices takes time looking and bidding for stuff all over the internet. Sure if I had lots of money I could buy everything even service to install of the things. I actually could drive the car to a shop and tell them install everything there is but then what would the car be for me? Just another vehicle I use to move from place A to B... Then I would also agree with you guys really not worth it...
But the feeling when you sit in the car and look at the things that you made work... Dam that satisfaction...
But back to the problem.
In my car I have 2-zone heater box, which has only 5 motors. There is no 2-zone ECU with rest to my knowledge, please correct me if you know better.
I already bought a new device which I thought to be 2-zone with rest, but it still was 3-zone. The new ecu has air-flow button where the left zone control button in the most 3-zone ecus are.
I do know I will have some errors in the system because I will be missing like 7-8 motors, air pollution sensor and the one sensor tat is connected to windshield. I did same swap on my W203 and it worked perfectly just plug and play.
What problems I do see now with the new system.
1. when I direct airflow to feet nothing happens.
2. I press air circulation, I will get error operation range malfunction and device is not programmed.
I cant run initial startup since it will fail or auto synchronization. I did try these with the RHD ecu and I'm stuck with error messages that Initial startup failed, don't know how to get rid of them on that ECU.
The problem 1. I think I can fix by setting the defrost vent right address to foot well left. the problem n.2 might be fixed by running the single motor programming command but I'm not sure since I can read the programmed values of the motor.
