  • 21 Vote(s) - 2.76 Average
W204 retrofit REST
19
-.- give me your number which is 3 zone and has rest.
(11-14-2016, 03:15 PM)Aless91 Wrote: -.- give me your number which is 3 zone and has rest.
Ahh sorry, my native language is not English, thought you were going to see what suited my original version.
A2049001197 is the facelift one from W218
A2048309985 is the one from W204 yom07
Both are 3-zone. The pre-facelift and facelift ECU do have little different housing so the facelift one wont fit straight to pre-facelift W204 console or the face mask.
I think I cracked the mechanical malfunction problem. Runnin test with xentry I found a comment that flap calibration or flap normalization would record motor ranges to the hvac ecu. So it seems my hvac ecu has different ranges stored. Now the sad part is that there is no single motor calibration in xentry or vediamo. And since I only have 5 motors instead of the 12 I cant run the calibration.
Never stop a running system Smile
Finally all parts have arrives, and got the setup up and code in... But now I'm having a problem... Cant get the HVAC to turn on... I have 12V connected to 16- and 14+, and CAN to pin 1 high and 2 low. I have CAN writer setup on table with instrument cluster hooked on and it does turn on. So I assume in WIS there is the signal 1 from EIS 15circuit info which I assume tells the devices to turn on. If someone have a glue what I'm missing, please give a shout.
This might be a little more advanced than most people play with, but if some knows about this stuff, I would be more than happy to collaborate. Still doing this as a hobby [emoji1]
[Image: dbc8f6f15d1ff9f015532ddc351cfd25.jpg]
MBRetrofitsFIN - You share, I share...
120 Ohm terminating resistor between CAN hi and lo
(02-03-2017, 03:56 AM)Mackhack Wrote: 120 Ohm terminating resistor between CAN hi and lo
I have wire from my can usb adapter to board where I have 110ohm(just because that was easiest to find =o) and from that board wires go to hvac. I tried the same wire to instrument cluster and it works just fine.
Thank you for pointing out.
Thanks given by: Powerpaul
