  • 18 Vote(s) - 3.06 Average
W211 E220 need battery drain fix?
10
This is a very nice video to help with the parasitic battery drain
https://www.youtube.com/watch?v=T6rDTtxaeJ4
Art Tup
SD4 won't necessarily tell fault component.
W211 does not have coolant heater, but some models have heater in breather hose.
search WIS document AR54.10-P-1030T for quiescent current hunt
Well well.. i am getting closer a complete no drain. but this isn't the solution.
By now i have UNPLUGGED EVERY RELAY AND FUSE in
ENGINE BAY FUSE BOX
LOAD AREA FUSE BOX
SPARE WHEEL FUSE BOX
FASCIA FUSE BOX
I also have a 30A fuse on no F83 - which is according to autodata only for government vehicles - i cannot look info up anywhere, does anyone of you know?
With pretty much every fuse box disconnected the draw is now narrowed down to 280 mA - i guess the rest of the draw is over fuses under carpet (footwell fuse box).
But why does every component draw somewhere between 40-80 mA? Do i have faulty earth connections, or canbus fault or? I cannot drive a car with 60+ fuses missing.
Btw - i only got the car for a 3weeks+ and the first 7-10 days there hasn't been any trouble and i haven't touched the car.
are you sure can bus is off? if bus is active many ecu drain. if active disconnect one at a time jumper can one ecu keeps active can communication
Thanks given by: diagnostik
14
Small update.
I have still disconnected all fuses, and both front and rear sam.
There is no draw at all now. If i then assemble fascia fuse box it instantly goes back to 80-90 mA - caused by door modules, radio unit and control module.
Also, is there a fix for sam modules? or do i really need to replace entire car modules - doors, radio unit, sam modules and so on? or is it an update in software?
SAM module doesn't show any error codes and everything works on car, but when i add connections to module the amp draw increases, and is reaching 600 mA with all cable connections plugged in - could the module be faulty or is it the components that i am connecting i should investigate further?
Use this information to check voltage drop.
Dont pull fuses out, use good multimeter switch it on mV and DC range.
And you can find where is problem.
All readings should be zero.
.pdf
Service Information_ Quiescent current test via voltage drop at the fuses.pdf
167
109.83 KB
It just makes me feel good Thankyou
Thanks given by: howlett , sec5klp , amber , cristofer , saturn54
17
(10-24-2016, 01:48 PM)Raints Wrote: Use this information to check voltage drop.
Cheers :-) the problem is now when connecting sam module to positive and then add cable connections to sam (no fuses in sam) the draw increases. So is the sam defective? I found 100mA draw on left front door module and fuse 83 in spare wheel well 150mA - those two fuses are pulled out and the draw is now only 13-15mA.
But now when i connect front sam with all cable connections it goes straight back to 600 mA
You must be sure that car is sleeping!
