W211 E220 need battery drain fix? - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: W211 E220 need battery drain fix? (/Thread-W211-E220-need-battery-drain-fix) |
W211 E220 need battery drain fix? - Laegaard - 10-23-2016 Hi ppl. I hope someone around here could help me getting closer to a permanent drain fix? I measure a total draw of 1,6-1,7 amp. This is when car is supposed to be asleep, and wiper is set to auto, and lightswitch is set to auto - anything else is turned off. I have unplugged every single fuse in fascia and load area and it came down to these readings. FASCIA F21 - 61 mA (right rear door module) F21 - 80 mA (right front door module) F28 - 340 mA (audio unit) F31 - 110 mA (multifunction control unit) F32 - 64 mA (left rear door module) F33 - 92 mA (left front door module) F36 - 50 mA (heated front seats) F37 - 3 microA (air suspension) F40 - 20 mA (multi switch assembly control module) F41 - 81 mA (can control module) F42 - 44 mA (load interrupting relay / control module) LOAD AREA F9 - 190 mA (sunroof control module) F11 - 30 mA (tailgate control module) F19 - 40 mA (seat lumbar pump) Total: 1.192 Amp. I guess the rest of the draw is somewhere in engine bay fuse box. Can it really be that almost every component in the car is reaching its end? or am i having a bigger issue elsewhere? Bad earth connections or? It's really annoying, the car drains battery over night. Both batteries are "new" 2 years approx. RE: W211 E220 need battery drain fix? - alexjx - 10-23-2016 w211 with electric seat? possible seat control module(below seats) are leaking. RE: W211 E220 need battery drain fix? - Laegaard - 10-23-2016 (10-23-2016, 06:37 PM)alexjx Wrote: w211 with electric seat? Yes it does have electric seats - what do you mean about leaking? could you please explain a bit
RE: W211 E220 need battery drain fix? - alexjx - 10-23-2016 (10-23-2016, 07:06 PM)Laegaard Wrote:(10-23-2016, 06:37 PM)alexjx Wrote: w211 with electric seat? in my experience(not much tho), these w211 seat module tends to leak voltage.(not sure the correct term) Try to remove the fuses to the seats and check again. the fuses are at the side dash. RE: W211 E220 need battery drain fix? - Laegaard - 10-23-2016 I have unplugged all fuses in load area and fascia and it still draws around 600 mA. I don't know whats normal, but it sure does drain battery pretty quickly. RE: W211 E220 need battery drain fix? - mersum1es - 10-23-2016 (10-23-2016, 07:23 PM)Laegaard Wrote: I have unplugged all fuses in load area and fascia and it still draws around 600 mA. I don't know whats normal, but it sure does drain battery pretty quickly. Try unplug alternator wires. Faulty voltage regulator may cause current drain... CAN bus awake can draw too current, you may try to isolate faulty component by unplugging first CAN connectors and if you find a connector that stops current leak, see what devices are behind that bus. RE: W211 E220 need battery drain fix? - Laegaard - 10-23-2016 (10-23-2016, 08:34 PM)mersum1es Wrote:(10-23-2016, 07:23 PM)Laegaard Wrote: I have unplugged all fuses in load area and fascia and it still draws around 600 mA. I don't know whats normal, but it sure does drain battery pretty quickly. Great info there, but if there's a draw on can bus how should i fix it? would it be "easier" if i had a sd c4 tester? for now i have unplugged all door modules, sunroof unit, radio unit and bcm. the battery drain is now much less, but still a voltage drop from 12,56 to 12,25 after just 1,5 hrs. RE: W211 E220 need battery drain fix? - JAMES1984 - 10-23-2016 (10-23-2016, 08:54 PM)Laegaard Wrote:(10-23-2016, 08:34 PM)mersum1es Wrote:(10-23-2016, 07:23 PM)Laegaard Wrote: I have unplugged all fuses in load area and fascia and it still draws around 600 mA. I don't know whats normal, but it sure does drain battery pretty quickly. Check to see if this vehicle is fitted with aux coolant heater just above starter,difficult to see but you will see the main cable going onto it.this aux heat is a common amp drain issue.just disconnect power lead to heat + insulate well = sorted. also,open bonnet and removed cover of front fuse box (sam).see if there is water present = dry sam + recheck - replace front sam (used one will be fine) RE: W211 E220 need battery drain fix? - Laegaard - 10-23-2016 (10-23-2016, 09:09 PM)JAMES1984 Wrote:(10-23-2016, 08:54 PM)Laegaard Wrote:(10-23-2016, 08:34 PM)mersum1es Wrote:(10-23-2016, 07:23 PM)Laegaard Wrote: I have unplugged all fuses in load area and fascia and it still draws around 600 mA. I don't know whats normal, but it sure does drain battery pretty quickly. I'll go have a look. Engine fuse box is dry and sealed. |
