Hi ppl.
I hope someone around here could help me getting closer to a permanent drain fix?
I measure a total draw of 1,6-1,7 amp. This is when car is supposed to be asleep, and wiper is set to auto, and lightswitch is set to auto - anything else is turned off.
I have unplugged every single fuse in fascia and load area and it came down to these readings.
FASCIA
F21 - 61 mA (right rear door module)
F21 - 80 mA (right front door module)
F28 - 340 mA (audio unit)
F31 - 110 mA (multifunction control unit)
F32 - 64 mA (left rear door module)
F33 - 92 mA (left front door module)
F36 - 50 mA (heated front seats)
F37 - 3 microA (air suspension)
F40 - 20 mA (multi switch assembly control module)
F41 - 81 mA (can control module)
F42 - 44 mA (load interrupting relay / control module)
LOAD AREA
F9 - 190 mA (sunroof control module)
F11 - 30 mA (tailgate control module)
F19 - 40 mA (seat lumbar pump)
Total: 1.192 Amp.
I guess the rest of the draw is somewhere in engine bay fuse box.
Can it really be that almost every component in the car is reaching its end? or am i having a bigger issue elsewhere? Bad earth connections or?
It's really annoying, the car drains battery over night. Both batteries are "new" 2 years approx.
FASCIA
LOAD AREA
Total: 1.192 Amp.
