Raito00
Location OfflineJunior Member
75
Thanks Given: 79
Thanks Received: 149 (17 Posts)
84
18
10-31-2016, 10:38 PM
Hi!
My problem is when the car is hot - working temperature. After turn of engine cant start anymore. Getting the ESP Malfunction and the car won't crank not turning starter. Wait when engine little cool down and then again can start engine.
I also realize when cant start also glow plug lamp on dash not comes at all!
One guy told me it is MB engine ECU common problem.
Maybe some one also have experience with this problem, and can confirm it is engine ECU problem.
BR
Raito
W211 - E320
2,095
Thanks Given: 14574
6,536
46
Yes, it fails to close the circuit 87 relay..
29
Thanks Given: 257
Thanks Received: 237 (129 Posts)
421
50
It should be internal ecu problem.
I am looking also solution for this problem.
Thanks Given: 12
Thanks Received: 21 (14 Posts)
56
Main processor needs re- flowing or re- balling ,whatever they call it.
362
Thanks Given: 101
Thanks Received: 761 (44 Posts)
166
29
I think this a Driver fault inside ecu, the driver short circuit when is hot and not send enough GND to Main Relay activation. Check GND in Main Relay when car start and when not crank.
If i am in correct way, you can pull out Main Relay and do a bridge between 30 pad and 87 pad of Relay Socket, car may start.
If you measured the GND in relay activation and is not enought, you can follow wire way inside ecu and must end in Driver 30460 Bosch (if i remember..)
103
Thanks Given: 474
Thanks Received: 840 (531 Posts)
1,358
41
If engine starts while it's cold but not when it's hot it's most likely the crankshaft position sensor. If indeed it is that (not sure since you state an ESP fault), try this:
Switch ignition to pos 2, turn heater to "hi", blower to max, turn ignition off to save battery, push REST button and let heat dissiapate for about 15-20 min until water temp is below 40 degrees C. If engine starts again you got your culprit.
The reason is this: CPS is a magnetic reed sensor that over time goes bad from the heat. Heat let's The magnet inside dilate and it starts sending false data to your ME. ME can't interpret data of where the crankshaft position is and won't allow engine to start.
Positive side effect of renewing CPS: your car gains naturally more power, drives more agil nicht the data is super crisp and on the spot. The runs smoother and you can tell just in idle it wants to go again.
This is a method I used twice already on both of my W211 to make it home when each CPS died on me while being out and about.
Raito00
75
Thanks Given: 79
84
18
Thanks to all for info!
My engine ECU is on way to guy who will re- flow it.
I will let know when it come back and try to drive
Thanks!
W211 - E320
2,095
Thanks Given: 14574
6,536
46
(11-01-2016, 10:49 AM)Mackhack Wrote: If engine starts while it's cold but not when it's hot it's most likely the crankshaft position sensor.
Its a no crank, no start..
