  • 12 Vote(s) - 2.58 Average
W212 Engine light ON.
Dear MHH Members,
I have a W212 E 250 M271 EVO, the car was running normally, client stop on traffic light, suddenly the engine light appear the car shake a little but did not shutdown. I perform diagnostic and get this DTC. See picture.
I erase DTC, tells the client to drive the car and if Engine light is on again contact me. Now 3 days had passed and no call from client. Can someone here help me concerning this DTC.
i see battery voltage is low at time of fault39
Thanks given by: MegaCar
(01-15-2017, 06:26 PM)KriyenKPp Wrote: i see battery voltage is low at time of fault39
Yes I agree but will a low voltage cause only this DTC, I did not ask client how long is the battery. I will do it soon. Any other idea Sir.
putting my money on a new coolant thermostat.
(01-15-2017, 07:07 PM)alexjx Wrote: putting my money on a new coolant thermostat.
I think about it but for 3 days now the car is running fine. Is the thermostat the root cause of the problem?
If you are living in an cold weather country than check the Anti Freeze level first......
Thanks & Best Regards
Ash
(01-15-2017, 07:45 PM)Ashraf6119 Wrote: If you are living in an cold weather country than check the Anti Freeze level first......
Am not living in a cold country but coolant level is good and the quality also is good.
Thanks given by: Ashraf6119
i once encountered this same problem.
then being cheapskate, i routed another wire to the sensor.(to isolate cable harness breakage)
then i changed the thermostat, and problem went away.
everything looks fine outside, but when i opened it, it looks melted/rotted interior.
maybe i was lucky it was a thermostat problem.
I dont think vehicle has problem with coolant system. The error code is the result of engine speed jumped down (328 and 282/min). Looks like the reason of lowering crankshaft speed is low fuel high pressure - 54 and 49 bars when ECU's specified value was 109 bars.
If problem occurs again I think you need to check high pressure fuel system.
