W212 Engine light ON. - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: W212 Engine light ON. (/Thread-W212-Engine-light-ON) Pages:
W212 Engine light ON. - MegaCar - 01-15-2017 Dear MHH Members, I have a W212 E 250 M271 EVO, the car was running normally, client stop on traffic light, suddenly the engine light appear the car shake a little but did not shutdown. I perform diagnostic and get this DTC. See picture. I erase DTC, tells the client to drive the car and if Engine light is on again contact me. Now 3 days had passed and no call from client. Can someone here help me concerning this DTC. Thanks RE: W212 Engine light ON. - KriyenKPp - 01-15-2017 i see battery voltage is low at time of fault
RE: W212 Engine light ON. - MegaCar - 01-15-2017 (01-15-2017, 06:26 PM)KriyenKPp Wrote: i see battery voltage is low at time of fault Yes I agree but will a low voltage cause only this DTC, I did not ask client how long is the battery. I will do it soon. Any other idea Sir. Thanks RE: W212 Engine light ON. - alexjx - 01-15-2017 putting my money on a new coolant thermostat. RE: W212 Engine light ON. - MegaCar - 01-15-2017 (01-15-2017, 07:07 PM)alexjx Wrote: putting my money on a new coolant thermostat. I think about it but for 3 days now the car is running fine. Is the thermostat the root cause of the problem? Thanks RE: W212 Engine light ON. - Ashraf6119 - 01-15-2017 If you are living in an cold weather country than check the Anti Freeze level first...... RE: W212 Engine light ON. - MegaCar - 01-15-2017 (01-15-2017, 07:45 PM)Ashraf6119 Wrote: If you are living in an cold weather country than check the Anti Freeze level first...... Am not living in a cold country but coolant level is good and the quality also is good. Thanks RE: W212 Engine light ON. - alexjx - 01-15-2017 (01-15-2017, 07:09 PM)MegaCar Wrote:(01-15-2017, 07:07 PM)alexjx Wrote: putting my money on a new coolant thermostat. i once encountered this same problem. then being cheapskate, i routed another wire to the sensor.(to isolate cable harness breakage) then i changed the thermostat, and problem went away. everything looks fine outside, but when i opened it, it looks melted/rotted interior. maybe i was lucky it was a thermostat problem. RE: W212 Engine light ON. - A2ua - 01-15-2017 I dont think vehicle has problem with coolant system. The error code is the result of engine speed jumped down (328 and 282/min). Looks like the reason of lowering crankshaft speed is low fuel high pressure - 54 and 49 bars when ECU's specified value was 109 bars. If problem occurs again I think you need to check high pressure fuel system. |
