  • 23 Vote(s) - 3.48 Average
WIS Configuration Tool with universal Key
100
I seem to have a problem with EWA application server it won't start
Hi, have Xentry XDOS installed and it worked well. When I install WIS and activate with 2025 key it works but then XENTRY shows config tool in which only VCI and SIM appears, no sdconnect. Is it becuase of the key in WIS?
how do I make both XENTRY and WIS work together?
(02-14-2024, 09:56 PM)macbut999 Wrote: I seem to have a problem with EWA application server it won't start
PM me
(03-09-2024, 06:17 PM)baletak Wrote: Hi, have Xentry XDOS installed and it worked well. When I install WIS and activate with 2025 key it works but then XENTRY shows config tool in which only VCI and SIM appears, no sdconnect. Is it becuase of the key in WIS?
What version of XDOS you installed ??
Services:
- MB SW,Trucks,Cars
- Smart SK
- Ved_DTS Cod
- EGR, SCR, DPF & Adblue OFF
- EPC On/Off line (Cars,Trucks)
- AutoVEI, DIMSport, Jaltest,VCX,C4,EngineDance,ECUmaster
hi
WIS config tool keep delete the KEY
when i open Xentry
any solution
Thanks+Rep. if I helped you...
(04-03-2024, 02:52 AM)Ah.E1Deeb Wrote: hi
when i open Xentry
any solution
I don't think WIS config tool deletes the key. Are you using some XDOS installation tools or other fixes that save Xentry license somewhere else in the HDD and then copies the license file at every Xentry start? In this case you should enter the WIS key to the "safe folder" file or copy the license file to the safe folder after entering the WIS key.
Thanks given by: Rocinante
105
Hello, would you like to explain the "save folder"?
I experience the same phenomena that the WIS key is lost when I first start Xentry and then start WIS. If I do it vice versa it still works.
One more thing: If WIS and Xentry is open and I stop WIS but start it again the WIS Key is lost again while Xentry is open. I do not get it what I do wrong?
Update: The WIS standalone works well after fresh installation of Windows 11, XDOS 9_23 and WIS. In this case I used the full fix from Samik and used the Xentry to WIS fix as well. Now it works stable.
Tried it with Xentry Passthru 09/2020. The tool didnt started.
Installed Xentry Passthru 03/2024. Now everything works fine.
Thank you very much !
MB W211 / 203
Speak: German, English and Russian
Key is'nt working for me.
Do I have to activate xentry (XDOS_24.9.4) before?
