  • 23 Vote(s) - 3.48 Average
WIS Configuration Tool with universal Key
118
the post 1
lic expire 2025.12.12,still can work. do not need 12-2026
DTS9.04.016
MB software
206223coding
M6+ Pro,C3
DS,Citroen,Peugeot Online
Lexus online//DST010
Thanks given by: luki03
119
Can someone please spot a mistake in my steps?
1. Installed Wis 2021.07
2. Installed XENTRY from https://xentryupdateservice.i.mercedes-b...24.9.3.zip
3. Installed WISConfigTool_7_21.exe
4. Ran WISConfigTool and used "WIS Uni Key with Print expire 12_12_25.txt" from the first post.
Getting "Provided StartKey is invalid". Note I did not activate or patch XENTRY, only installed and rebooted the computer.
(01-25-2025, 09:54 PM)pashu0007 Wrote: Getting "Provided StartKey is invalid". Note I did not activate or patch XENTRY, only installed and rebooted the computer.
That's why you have an error
Thanks given by: Rocinante
121
(01-25-2025, 09:54 PM)pashu0007 Wrote: Can someone please spot a mistake in my steps?
after Install Xentry we can't install WIS 2021.07?
WIS 2021.07 is not affected by XENTRY.
DTS9.04.016
MB software
206223coding
M6+ Pro,C3
Hi guys,
Thank you for the files.  I installed wis_072021.iso but when launching the app,  the resolution is so small, it's difficult to see the buttons.  How do I fix this?
Thanks given by: hgmdiag
124
C:\ProgramData\Mercedes-Benz\Fremdsoftware\WIS\wisnet
edit wis_cfg.xml this way:
<SECTION name="standard">
<PARAMETER name="fontsize">16</PARAMETER>
depending on your screen and resolution you may try 16,...17,...18,..19.....till fine tune it
good luck
Thanks given by: glc300 , Rocinante , malkia , Wetwiki , vanos325i
125
(02-10-2025, 08:13 PM)weryo Wrote: C:\ProgramData\Mercedes-Benz\Fremdsoftware\WIS\wisnet
good luck
The menu overlapped on my laptop but desktop works fine.  Thank you
hello
can use wisconfig tool with xpt 2020 2021 version or need a 2022 version any solution to run wisconfigtool in old XPT?
I installed in one 2020 xpt systen and not opend tool ,any idea to fix and open tool for write actual key?
any active download link for try old starkeycenter method ? I not fin any active
thanks
