Mercedes CLA 118 Tow Bar Problem
I have installed a Tow Bar on my Vehicle. The problem is, that nothing happens when I actuate the switch. I then noticed that the control unit indicates the Tow Bar has not been initialized (Image Initialize).
But i can´t initialize ,upon checking the actual values, I saw that the Tow Bar is listed as "unlocked"!?
However, it *is* locked.
I then proceeded to measure the wiring.
Measuring between (Image Schematic)Sens_GND and Sen_2 (Pins 5 and 7): Pin 5 shows continuity, but Pin 7 does not. I tried grounding both pins, but the status display in the actual values did not change not even when I actuated the switch.(Image Values)
When the Tow Bar is locked. Witch SEN2 Pin 5 & 7 has continuity.
Initial startup was not performed.
  • SW Seed\key VGS\MED\IC virgin\hard coding Carplay HU5s1 HU5es2 any fw
  • HW Genuine XentryConnect-SDConnect-eCom sale\repair\parts\setu
(05-21-2026, 09:39 PM)Anturage Wrote: Initial startup was not performed.
Have you read my Post carefuly!? It doenst work because the restriciton Tow bar is locked is not complete
Read second time - same solution
(05-21-2026, 10:07 PM)Anturage Wrote: Read second time - same solution
Do you see in the Picture?
But i found the Failure. It is mechaniclly blocked.
I plug off the Motor. What does the Shaft Do?
So i fixt it with WD40  Wink
Another Question.: Has anyone a Backup of Coding from the Tm205 please!?
(05-23-2026, 03:22 PM)Sebi76 Wrote: So i fixt it with WD40  Wink
I have, write pm for which car do you need it
- NTG 3.5-Gen20x map pin
- USA/Canada/Japan conversion
- remote retrofit/codings/programming
W206 W254 W223 REMOTE CODINGS
Thanks given by: Sebi76
That works for me. Perfect Thanks
06-07-2026, 01:30 PM
05-03-2026, 04:35 AM
05-01-2026, 02:39 PM
