16
Thanks Given: 756
Thanks Received: 180 (68 Posts)
127
10
10-04-2016, 09:27 AM
Hey guys
I try to connect to AUDIO 20 Head unit and in xentry DAS it was success to comunication . but the vediamo could not be connect . i use the HU25 cbf file. the unit was belong to the W251 .
one i connect to the head unit ,message below presents.
12:09:47 Error: Unable to establish communication with ECU. Reason: CAESAR:ComCoordinator: 01025: PDUAPI: 0x0101 PDU_ERR_EVT_TX_ERROR (CLL/CoP Error: Error enc
whether is my wrong cbf file or not. i don't find the other cbf can be used.
and i try to connect the CGW with the ZGW164 cbf, it waw success established.
mike gao
my friend make me strong , cause he know some thing which i don't know.
130
Thanks Given: 1270
Thanks Received: 635 (279 Posts)
673
17
10-04-2016, 12:45 PM
If you want a product/device support it has to come from the respective manufacturer! These are common problems with vediamo. I once had a similar error on a w203 up to 2008 in das.
CBF (Caesar Based Files) on xentry must be different, why do you think that vediamo installation manuals says u get CBF, VSB , CFF, CCF, vediamoshorttest data and kursztest files from vediamo intranet which was closed by ''manufacturer'' I don't know when.
And this files have a directory which can be manipulated yes, buy manual never says u can get them from Xentry
We should try and focus more on DTS Monaco- it's in use and has support. Vediamo is good for those who had all the files long ago when they we're available
“We, the unwilling, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, for so long, with so little, we are now qualified to do anything with nothing.”
16
Thanks Given: 756
127
10
(10-04-2016, 03:06 PM)laco210 Wrote: Try right click on ecu and in properties you can have more protocols so select the right one. For example CR4 you can have there KW2C3PE_500 and also KW2000PE_10_4 and you have to set KW2C3PE_500 for connection with ecu or try use XHU.cbf
Don't work !
i think the correct cbf file should be the HU25, cause i try to delete it when it was connected with the SD diagnosis , it was blocked.
alos i try to delete it before connect the head unit. error message pop up.
so may be it was the vediamo problem. i guess.
mike gao
