Which cbf file i need? w251 head unit - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Which cbf file i need? w251 head unit (/Thread-Which-cbf-file-i-need-w251-head-unit) |
Which cbf file i need? w251 head unit - mike gao - 10-04-2016 Hey guys I try to connect to AUDIO 20 Head unit and in xentry DAS it was success to comunication . but the vediamo could not be connect . i use the HU25 cbf file. the unit was belong to the W251 . one i connect to the head unit ,message below presents. 12:09:47 Error: Unable to establish communication with ECU. Reason: CAESAR:ComCoordinator: 01025: PDUAPI: 0x0101 PDU_ERR_EVT_TX_ERROR (CLL/CoP Error: Error enc whether is my wrong cbf file or not. i don't find the other cbf can be used. and i try to connect the CGW with the ZGW164 cbf, it waw success established. mike gao RE: Which cbf file i need? w251 head unit - Dollsburg - 10-04-2016 If you want a product/device support it has to come from the respective manufacturer! These are common problems with vediamo. I once had a similar error on a w203 up to 2008 in das. CBF (Caesar Based Files) on xentry must be different, why do you think that vediamo installation manuals says u get CBF, VSB , CFF, CCF, vediamoshorttest data and kursztest files from vediamo intranet which was closed by ''manufacturer'' I don't know when. And this files have a directory which can be manipulated yes, buy manual never says u can get them from Xentry We should try and focus more on DTS Monaco- it's in use and has support. Vediamo is good for those who had all the files long ago when they we're available RE: Which cbf file i need? w251 head unit - laco210 - 10-04-2016 Try right click on ecu and in properties you can have more protocols so select the right one. For example CR4 you can have there KW2C3PE_500 and also KW2000PE_10_4 and you have to set KW2C3PE_500 for connection with ecu or try use XHU.cbf
RE: Which cbf file i need? w251 head unit - mike gao - 10-05-2016 (10-04-2016, 03:06 PM)laco210 Wrote: Try right click on ecu and in properties you can have more protocols so select the right one. For example CR4 you can have there KW2C3PE_500 and also KW2000PE_10_4 and you have to set KW2C3PE_500 for connection with ecu or try use XHU.cbf Don't work ! i think the correct cbf file should be the HU25, cause i try to delete it when it was connected with the SD diagnosis , it was blocked. alos i try to delete it before connect the head unit. error message pop up. so may be it was the vediamo problem. i guess. mike gao |
