  • 9 Vote(s) - 4.22 Average
XDOS diagnosis with ENET cable solution
19
(12-24-2023, 02:32 PM)abhishek943 Wrote: Hi OP
Does this work on all merc cars till date or specific ones only?
TIA
Hi
ENET cable connection is only for DoIP protocols model ,W223 , W206 , ..... and EQ ..........
Best Regards
If my post can help you , Thanks + Reputation will be appreciated  Kolo
Thanks given by: Rocinante , abhishek943 , ManitouSmoke , PicP1x
20
Hi. Great works, but what this .exe modify on the system?)
nothing modify,..just start it in doip only mode,..all is originall
Thanks given by: temo4ka
22
Is it correct that this solution works on releases up to 09/2023? Does an update for later releases exist?
23
TIA
Hi
Best Regards
But, what I have understood, you can flash old HU (NTG5*2) with Bmw enet cable (for example)
Is it true?
yes thats correct
Thanks given by: ManitouSmoke
25
anyone tested with offline login for XDOS 6.2024 , Cuz it seems not working with login
Thanks+Rep. if I helped you...
All work ok
(06-17-2024, 04:40 PM)Ah.E1Deeb Wrote: anyone tested with offline login for XDOS 6.2024 , Cuz it seems not working with login
Looks like Avast says this has a Trojan in it?
If my solution helped, please consider adding a thanks and/or rep+
