  • 9 Vote(s) - 4.22 Average
XDOS diagnosis with ENET cable solution
28
Maybe there's someone who can help me.
I have the 09.2023 and after using the enet-solution my xentry wont connect right to the car anymore with my C4. (Vediamo and Monaco are working)
I can start the identification and xentry finds the right car and sees the vin but then the error "diagnosis plug not connected" appear.
Tried deleting xentry and reinstalling but the problem stays. Someone have an idea?
Tried another notebook and there it works.
Thank you for the great piece of software and I hope someone can help.
Best greets
Nacka
(07-11-2024, 06:16 PM)Nacka Wrote: Maybe there's someone who can help me.
Best greets
Nacka
Check IPs for C4
Thanks+Rep. if I helped you...
Checked it, looks right to me and the vin are readed but the diagnosis itself wont start right.
@Nacka You need to set  up the DoIP Adresse in the IP Settings, too. Below the IP Adress there is a field "Erweitert", there put in the DoIP Adresse 169.254.0.** (i.e 169.254.0.45)
Thanks given by: Galahead
32
My problem is that I cant use my C4 anymore on this notebook since i used the enet-tool. I dont know if it's the tool or my fault so i tought i could ask for help.
Maybe the tool change something in the registry I didnt find?
Thanks given by: fotom
33
(07-12-2024, 12:33 PM)Nacka Wrote: My problem is that I cant use my C4 anymore on this notebook since i used the enet-tool.  I dont know if it's the tool or my fault so i tought i could ask for help.
maybe you4 C4 need update or something
if you still face trouble, feel free pm with anydesk
Thanks given by: Nacka
34
(07-12-2024, 02:25 PM)Ah.E1Deeb Wrote: maybe you4 C4 need update or something
Eldeeb solved the problem. Thank you a lot.
Reinstall didn't helped, the reconfig over ConfigAssist was the solution.
Thank you a lot!
Thanks given by: weryo , fotom , uchtool
35
Has anyone try this enet solution with 2024.06 ?
Translator
(05-30-2023, 02:16 PM)benjaminjai Wrote: for XDOS only -- allows connection to DoIP only models (223, 206, 214, EQmodels, etc) with just an ENET cable
should work with all versions of XDOS from 09/2021 to current release.
tested working on 06/22 09/22 12/22 and 03/23
03/2023 - must have addon 26391 installed.
password: mhhauto.com
thanks u for sharing NOT test yet but thanks u your spported
Translator
Best greets
Nacka
if i was u i should clone hdd out and make keys for another pc with clone xentry and test out Enet cable without risky lost the pc xentry ready run with C4, this whati do all my pc computer , alway back up or clone out extra hard ssd so if some wrong i can have spare to use it, not let risky run one hard drive & if corrupted & dead hard drive then u doom, i am not epxert like any one else's but this what have to spend $ by extra ssd hard driver to clone each software & created backup just incase etc..
Thanks given by: mercomoh
