  • 43 Vote(s) - 3.23 Average
XENTRY 01/2011 Error
Hello All
I did installation DAS 01/2011
The DAS works perfectly
When I make my diagnosis turns out XENTRY
message
(1.17) -7.870
(2.27) -7,870
You can help
thanks
your multiplexer is blacklisted!
Thanks given by: narf003
(02-10-2011, 11:03 PM)takis Wrote: Hello All
message
(1.17) -7.870
(2.27) -7,870
You can help
thanks
You multiplexer is blocked
Try this, but this file on to F:\Programme\Xentry\bin\llis
If it helps, don't forget to but "thanks" button.
cal_870.rar
526
692 bytes
message
(1.17) -7.870
(2.27) -7,870
You can help
thanks
Thanks friend
Xentry everything is OK
Hello, i am installing xentry 1/2011 to Vmware pc, when i try to enter xentry key in star utilities i can't enter anything in field start and end date. Is this normal? And when i enter key i get message: star key cannot be decoded.
How to solve this problem?
(02-14-2011, 12:05 AM)beha Wrote: Hello, i am installing xentry 1/2011 to Vmware pc, when i try to enter xentry key in star utilities i can't enter anything in field start and end date. Is this normal? And when i enter key i get message: star key cannot be decoded.
Hi there,
1st finish ur DAS installation, then post ur Xentry LAN ID to generate for u developer key that works with AppID 253.
gd Luck.
Kolo
[Image: mhhsig.gif]
Hi there,
gd Luck.
Kolo
Das installation finished ok, everything worked. Xentry lan id is: 674022A1EF2B Appid: 253
One more question, i tried to change Appid to 252, does not work, why?
Hi there,
gd Luck.
Kolo
Already there is one post here about how to change the App ID but I never tried it Smile
Anyway I think no need since here is ur key: P53C8N6BWTWUQQ548UCUD2PC938QVGSPFC9PDUE9BSB3NM2A3VYGDV7JSW6G8BY5SCDR9H3CYKCPJYMZ5QX2UUUCVJVT4Z6JG2BGAGVJ58C6Q5B38UQLN7SEUHX4P8Q5BS
P.S Remove the spaces
Kolo
[Image: mhhsig.gif]
message
(1.17) -7.870
(2.27) -7,870
You can help
thanks
great! Thanks a lot
Thanks given by: coolboyxxx , automan420 , pisiciki
