is it possible to change vin manually in Delphi engine ecu? Need to do this prior to learning it to the car. Otherwise, the car starts several times, then dies and the error <wrong vin number> appears. I attach the eeprom and ecu label.
need to change vin in Delphi ecu mb e220
10-25-2016, 04:33 AM
(10-24-2016, 11:28 PM)ruklis Wrote: is it possible to change vin manually in Delphi engine ecu? Need to do this prior to learning it to the car. Otherwise, the car starts several times, then dies and the error <wrong vin number> appears. I attach the eeprom and ecu label.
PM me vin you need programmed
10-25-2016, 12:10 PM
(10-25-2016, 04:33 AM)driiiven Wrote:(10-24-2016, 11:28 PM)ruklis Wrote: is it possible to change vin manually in Delphi engine ecu? Need to do this prior to learning it to the car. Otherwise, the car starts several times, then dies and the error <wrong vin number> appears. I attach the eeprom and ecu label.
your file - thanks + rep if this helped you out
Thanks given by: ruklis
11-03-2016, 01:11 AM
still no luck- starter is not being activated, when control module activation asks to start the engine.
