need to change vin in Delphi ecu mb e220 - Printable Version
+---- Thread: need to change vin in Delphi ecu mb e220 (/Thread-need-to-change-vin-in-Delphi-ecu-mb-e220)
need to change vin in Delphi ecu mb e220 - ruklis - 10-24-2016
is it possible to change vin manually in Delphi engine ecu? Need to do this prior to learning it to the car. Otherwise, the car starts several times, then dies and the error <wrong vin number> appears. I attach the eeprom and ecu label.
RE: need to change vin in Delphi ecu mb e220 - driiiven - 10-25-2016
(10-24-2016, 11:28 PM)ruklis Wrote: is it possible to change vin manually in Delphi engine ecu? Need to do this prior to learning it to the car. Otherwise, the car starts several times, then dies and the error <wrong vin number> appears. I attach the eeprom and ecu label.
PM me vin you need programmed
your file - thanks + rep if this helped you out
RE: need to change vin in Delphi ecu mb e220 - ruklis - 11-03-2016
still no luck- starter is not being activated, when control module activation asks to start the engine.
