  • 15 Vote(s) - 2.87 Average
need to change vin in Delphi ecu mb e220
is it possible to change vin manually in Delphi engine ecu? Need to do this prior to learning it to the car. Otherwise, the car starts several times, then dies and the error <wrong vin number> appears. I attach the eeprom and ecu label.
95320 w211 second ecu_virgin.rar
23
2.02 KB
(10-24-2016, 11:28 PM)ruklis Wrote: is it possible to change vin manually in Delphi engine ecu? Need to do this prior to learning it to the car. Otherwise, the car starts several times, then dies and the error <wrong vin number> appears. I attach the eeprom and ecu label.
PM me vin you need programmed
your file - thanks + rep if this helped you out
fixed.rar
18
1.44 KB
Thanks given by: ruklis
still no luck- starter is not being activated, when control module activation asks to start the engine.
