  • 22 Vote(s) - 2.64 Average
Xentry Openshell (C3) install problem
Tried to install XDOS Openshell 9/2016 and 12/2015 but both making error during intalling it. Error with 2016 i dont remember but 2015 version i check the log file and says following; "CustomAction DAIInstall returned actual error code 1603"
-and after that it unistall all installed stuff so far and wants to restart computer.
Laptop is old Compaq 615 with 160gb hdd including a lot of diagnostic stuff that i dont want to delete for a clean windows. (Win7 32bit)
To installing xdos i formated another part of hdd, but is this ok to use different disk than C:?
All kind of advice are welcome, actually i am trying to setup Star C3.
I am lost of these XDOS, XENTRY, DAS and stuff. Which one is the best to my solution?
Br, Mikko! bow
(11-13-2016, 11:33 PM)halooseppo Wrote: Tried to install XDOS Openshell 9/2016 and 12/2015 but both making error during intalling it. Error with 2016 i dont remember but 2015 version i check the log file and says following; "CustomAction DAIInstall returned actual error code 1603"
Br, Mikko! bow
Hi.
I would recommend using a harddisk solely for Xentry Das.
Swap HD when using other programs..
If going to use C3 mux, I believe You also would like to use an laptop with serial port (com port)...
For C3 , best working version would be 9-12.2014, depending upon car models..
In Your log, there is parts of interrest before 1603 error message..
WBR
MH
Thanks given by: benzcoupe
Thanks, "XENTRY Diagnostics OpenShell_2014.12-2015.1-2.rar" is now downloading...
Hope that works.
I´ve read somewhere that C3 mux will work also with usb-serial cable?
I put the log file to attach, what did you meant about something interesting? 39
log.rar
50
77.39 KB
(11-14-2016, 12:59 AM)halooseppo Wrote: Thanks, "XENTRY Diagnostics OpenShell_2014.12-2015.1-2.rar" is now downloading...
Hope that works.
I haven't heard of many people getting usb-serial cable to work well or at all. I have heard a lot of bad things about it.
I ended up using a PCI-E serial card, works great.
You can use any xdos version for C3, I recommend 07/2016 if you want newest software. I can help you if you need it.
Hope that works.
Things has changed for a while. A good usb-serial cable can work perfect with C3 muxes. FTDI Genuine ones for sure Smile
can u define 'genuine FTDI' please...
(11-14-2016, 04:01 AM)benzcoupe Wrote: can u define 'genuine FTDI' please...
Yes, for sure...Smile
Code:
http://www.ftdichip.com/Products/Cables/USBRS232.htm
Errors continues with new Win7 64bit and different hdd.
Any Ideas? What i do wrong Call
Br, Mikko! bow
I am using below image and is working very good. My PC is HP with serial port.
http://mhhauto.com/Thread-XDOS-12-2015-3...IMAGE-AHCI
