Xentry Openshell (C3) install problem - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Xentry Openshell (C3) install problem (/Thread-Xentry-Openshell-C3-install-problem) Pages:
Xentry Openshell (C3) install problem - halooseppo - 11-13-2016 Tried to install XDOS Openshell 9/2016 and 12/2015 but both making error during intalling it. Error with 2016 i dont remember but 2015 version i check the log file and says following; "CustomAction DAIInstall returned actual error code 1603" -and after that it unistall all installed stuff so far and wants to restart computer. Laptop is old Compaq 615 with 160gb hdd including a lot of diagnostic stuff that i dont want to delete for a clean windows. (Win7 32bit) To installing xdos i formated another part of hdd, but is this ok to use different disk than C:? All kind of advice are welcome, actually i am trying to setup Star C3. I am lost of these XDOS, XENTRY, DAS and stuff. Which one is the best to my solution? Br, Mikko! ![]() [attachment=154178] RE: Xentry Openshell (C3) install problem - MorseHan - 11-14-2016 (11-13-2016, 11:33 PM)halooseppo Wrote: Tried to install XDOS Openshell 9/2016 and 12/2015 but both making error during intalling it. Error with 2016 i dont remember but 2015 version i check the log file and says following; "CustomAction DAIInstall returned actual error code 1603"Hi. I would recommend using a harddisk solely for Xentry Das. Swap HD when using other programs.. If going to use C3 mux, I believe You also would like to use an laptop with serial port (com port)... For C3 , best working version would be 9-12.2014, depending upon car models.. In Your log, there is parts of interrest before 1603 error message.. WBR MH RE: Xentry Openshell (C3) install problem - halooseppo - 11-14-2016 Thanks, "XENTRY Diagnostics OpenShell_2014.12-2015.1-2.rar" is now downloading... Hope that works. I´ve read somewhere that C3 mux will work also with usb-serial cable? I put the log file to attach, what did you meant about something interesting?
RE: Xentry Openshell (C3) install problem - EASatlanta - 11-14-2016 (11-14-2016, 12:59 AM)halooseppo Wrote: Thanks, "XENTRY Diagnostics OpenShell_2014.12-2015.1-2.rar" is now downloading... I haven't heard of many people getting usb-serial cable to work well or at all. I have heard a lot of bad things about it. I ended up using a PCI-E serial card, works great. You can use any xdos version for C3, I recommend 07/2016 if you want newest software. I can help you if you need it. RE: Xentry Openshell (C3) install problem - Marcos - 11-14-2016 (11-14-2016, 01:18 AM)EASatlanta Wrote:(11-14-2016, 12:59 AM)halooseppo Wrote: Thanks, "XENTRY Diagnostics OpenShell_2014.12-2015.1-2.rar" is now downloading... Things has changed for a while. A good usb-serial cable can work perfect with C3 muxes. FTDI Genuine ones for sure
RE: Xentry Openshell (C3) install problem - benzcoupe - 11-14-2016 can u define 'genuine FTDI' please... RE: Xentry Openshell (C3) install problem - Marcos - 11-14-2016 (11-14-2016, 04:01 AM)benzcoupe Wrote: can u define 'genuine FTDI' please... Yes, for sure... ![]() Code: http://www.ftdichip.com/Products/Cables/USBRS232.htmRE: Xentry Openshell (C3) install problem - halooseppo - 11-16-2016 Errors continues with new Win7 64bit and different hdd. Any Ideas? What i do wrong ![]() [attachment=154517] [attachment=154518] RE: Xentry Openshell (C3) install problem - TIGRI007 - 11-16-2016 (11-13-2016, 11:33 PM)halooseppo Wrote: Tried to install XDOS Openshell 9/2016 and 12/2015 but both making error during intalling it. Error with 2016 i dont remember but 2015 version i check the log file and says following; "CustomAction DAIInstall returned actual error code 1603" Hello, I am using below image and is working very good. My PC is HP with serial port. http://mhhauto.com/Thread-XDOS-12-2015-32BIT-SDCONNECT-ACRONIS-IMAGE-AHCI |
