Hi all,I need some help with a 2004 w203 2.1 cdi rhd with a abs light on,with fault code c1210 terminal 30. ive checked fuses under the bonnet drivers side all ok,could anybody help with fault tracing or wiring diagram for this terminal 30? much appreciated thanks
[email protected]
abs light on help c220 w203
07-08-2018, 12:03 PM
Check fuses once again..... In most cases these are not fuses but burned contats holding fufes. You need to clean or replace these.
My old contributions are not password protected. Get them if you need them. I will delete them in order to make space for new ones.
Thanks given by: Ashraf6119 , bram80
07-09-2018, 04:54 PM
If it is ATE unit then check brushes on pump motor.
Motor brushes is worn and then you get same fault code like no feed!
It just makes me feel good
Thanks given by: bram80 , FRIEDRICHKL
