abs light on help c220 w203 - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: abs light on help c220 w203 (/Thread-abs-light-on-help-c220-w203) |
abs light on help c220 w203 - bram80 - 07-08-2018 Hi all,I need some help with a 2004 w203 2.1 cdi rhd with a abs light on,with fault code c1210 terminal 30. ive checked fuses under the bonnet drivers side all ok,could anybody help with fault tracing or wiring diagram for this terminal 30? much appreciated thanks RE: abs light on help c220 w203 - efka - 07-08-2018 Check fuses once again..... In most cases these are not fuses but burned contats holding fufes. You need to clean or replace these. RE: abs light on help c220 w203 - bram80 - 07-08-2018 (07-08-2018, 12:03 PM)efka Wrote: Check fuses once again..... In most cases these are not fuses but burned contats holding fufes. You need to clean or replace these. hi do you know the fuse numbers i need to check? thanks RE: abs light on help c220 w203 - FRIEDRICHKL - 07-09-2018 It is fuse 59 and 60 in the front SAM. Wiring diagrams are attached RE: abs light on help c220 w203 - Raints - 07-09-2018 If it is ATE unit then check brushes on pump motor. Motor brushes is worn and then you get same fault code like no feed! RE: abs light on help c220 w203 - bram80 - 07-16-2018 (07-09-2018, 07:54 AM)FRIEDRICHKL Wrote: It is fuse 59 and 60 in the front SAM. Wiring diagrams are attached cheers found broken wire from fuse 60 to abs uint pin 1,so i run new wire tested all ok thanks for diagram fridrichkl
