  • 24 Vote(s) - 3 Average
bga key on w210
19
(12-27-2016, 11:55 AM)PedroX5 Wrote: I tried be key program to eis from w210 week ago, work well on first attempt. What do you use for program this key? Did you try to read a key on bench after programming again? ( you wrotte that are calculated on noimmo, they are programmed with this tool to?)
I had once problem with China key, there was problem with plastic covered ir port in front of keys. I exchanged this part for other one and its start to work well.
i have programmed the keys with MB Doctor from the Legend and friend also programmed keys with VVDI and all give same results.
somewhere you did some fault...Itwasntme
_Offer TOKENS for VVDI MB BGA Tool or all VVDI2 activations - Instant_
you can try to use other calculated key... ( I mean if you tried it for example with key 4, then try it with key 6...)
(12-27-2016, 04:18 PM)PedroX5 Wrote: you can try to use other calculated key... ( I mean if you tried it for example with key 4, then try it with key 6...)
i have try different key positions and Always same results.
have talk with a friend and he sayed he have same problem with the old w208/w210 ezs's.
i can't see what i'm doing wrong because if i use a NEC key i have no problem at all. everything work ok.
Its very strange, if you have a time, lets connect star to youre car ( as wrotte Daxxer) and you can check all status form EIS with youre NEC and BE keys .
Can you check now in ir key reader status of key?
car is allready left again.
but status from BE key is now 04FC.
and this is after whole night in ezs for activation.
only fault ezs is giving is B1156-005.
but car is running ok and everything is also working ok.
(12-29-2016, 09:08 PM)mikeburnet Wrote: car is allready left again.
anywhere isn't described, when activation time is only some seconds... Shake can be longer then one hour too Listen
Thanks given by: rokibar
26
by nec keys with this ezs activation time is seconds or 1 hour.
1 key activated is 1 seconds and others had 1 hour needed to activated.
For the old 208/210 EIS I use only original NEC keys, never BE. I have tried a few BE long time ago, but they either not activate or stop working after a few hours/days.
Thanks given by: mikeburnet , daxxer , PedroX5 , efka
