bga key on w210 - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: bga key on w210 (/Thread-bga-key-on-w210) |
bga key on w210 - mikeburnet - 12-26-2016 i have a w210 ezs and want to make a spare key bga type on it but have try everythig i can think off but key it wont activate. have left it several time hole night in ezs and no activation. have try to activate the key first and then insert in ezs (car) but it only release the esl and no activation. some one know the solution for this problem? or is it simple not possible because the w210 are to old? RE: bga key on w210 - daxxer - 12-26-2016 what you mean under word "activate" ?
RE: bga key on w210 - efka - 12-26-2016 Something is not right here unless he is using new (paired) keys with known ssid and doing it by dump renewing MSG and ESL but judging by his post this is not so. RE: bga key on w210 - mb_port - 12-26-2016 (12-26-2016, 11:35 AM)mikeburnet Wrote: i have a w210 ezs and want to make a spare key bga type on it generate key with skc,writte to be(china) key start car after work remote RE: bga key on w210 - mikeburnet - 12-26-2016 (12-26-2016, 12:57 PM)daxxer Wrote: what you mean under word "activate" ? that the key will trun when insert in ezs. (red led from key will go out). so change the code from 04FC to 14EC. (12-26-2016, 02:02 PM)efka Wrote: Something is not right here unless he is using new (paired) keys with known ssid and doing it by dump renewing MSG and ESL but judging by his post this is not so. i generate key by dump through skc and make new bga key. (12-26-2016, 02:59 PM)mb_port Wrote:(12-26-2016, 11:35 AM)mikeburnet Wrote: i have a w210 ezs and want to make a spare key bga type on it this is exacly what im doing but it dont work with this ezs. key will not get activated. RE: bga key on w210 - daxxer - 12-26-2016 (12-26-2016, 05:45 PM)mikeburnet Wrote:(12-26-2016, 12:57 PM)daxxer Wrote: what you mean under word "activate" ?that the key will trun when insert in ezs. (red led from key will go out). and in what state is your key with EZS now ?? ![]() key turn OK, but LED still light ON ? ![]() key not turning allowed, LED light ON ? ![]() key not turn, LED NO light ? ![]() or some other kombination ?? ![]() i not see any THX or REP in this thread at any posts till now ![]() Try for your HOMEWORK learn how to use THANKS and REPUTATION buttons !!! ![]() RE: bga key on w210 - mikeburnet - 12-26-2016 (12-26-2016, 05:56 PM)daxxer Wrote:(12-26-2016, 05:45 PM)mikeburnet Wrote:(12-26-2016, 12:57 PM)daxxer Wrote: what you mean under word "activate" ?that the key will trun when insert in ezs. (red led from key will go out). the state is now: key not turning allowed, LED light ON. left it overnight to get activated but not get activated. i can give THX or REP, that is no problem. if you see my other post i Always give THX or REP. only in this case there is only question and no solution thats why i did not give THX or REP. RE: bga key on w210 - daxxer - 12-26-2016 (12-26-2016, 06:09 PM)mikeburnet Wrote: the state is now: key not turning allowed, LED light ON. when the LED still light ON, but nothing more happen't, then: ![]() 1) your key data are not valid 2) key password isn't valid 3)your MCU soldering isn't okey try to use Star diagnostic to check faults in your EZS and you see what is the problem...
RE: bga key on w210 - mikeburnet - 12-27-2016 key data is ok and so is password and mcu's soldering. if i use a nec key then key get activated and start car without problem. have try 5 BE keys and all same result and 3 nec and 2 Motorola key and both work wihout problem. |
