  • 24 Vote(s) - 3 Average
bga key on w210
i have a w210 ezs and want to make a spare key bga type on it
but have try everythig i can think off but key it wont activate.
have left it several time hole night in ezs and no activation.
have try to activate the key first and then insert in ezs (car) but it only release the esl and no activation.
some one know the solution for this problem?
or is it simple not possible because the w210 are to old?
what you mean under word "activate" ? Itwasntme
_Offer TOKENS for VVDI MB BGA Tool or all VVDI2 activations - Instant_
Thanks given by: mikeburnet
Something is not right here unless he is using new (paired) keys with known ssid and doing it by dump renewing MSG and ESL but judging by his post this is not so.
(12-26-2016, 11:35 AM)mikeburnet Wrote: i have a w210 ezs and want to make a spare key bga type on it
generate key with skc,writte to be(china) key
start car after work remote
(12-26-2016, 12:57 PM)daxxer Wrote: what you mean under word "activate" ? Itwasntme
that the key will trun when insert in ezs. (red led from key will go out). so change the code from 04FC to 14EC.
(12-26-2016, 02:02 PM)efka Wrote: Something is not right here unless he is using new (paired) keys with known ssid and doing it by dump renewing MSG and ESL but judging by his post this is not so.
i generate key by dump through skc and make new bga key.
this is exacly what im doing but it dont work with this ezs.
key will not get activated.
and in what state is your key with EZS now ?? Itwasntme
key turn OK, but LED still light ON ? Itwasntme
key not turning allowed, LED light ON ? Itwasntme
key not turn, LED NO light ? Itwasntme
or some other kombination ?? Listen
i not see any THX or REP in this thread at any posts till now Fing20
1087 Try for your HOMEWORK learn how to use THANKS and REPUTATION buttons !!! 1087
Thanks given by: benzcoupe , bawarek
the state is now: key not turning allowed, LED light ON.
left it overnight to get activated but not get activated.
i can give THX or REP, that is no problem.
if you see my other post i Always give THX or REP.
only in this case there is only question and no solution thats why i did not give THX or REP.
(12-26-2016, 06:09 PM)mikeburnet Wrote: the state is now: key not turning allowed, LED light ON.
when the LED still light ON, but nothing more happen't, then: Listen
1) your key data are not valid
2) key password isn't valid
3)your MCU soldering isn't okey
try to use Star diagnostic to check faults in your EZS Pc and you see what is the problem... Nod
key data is ok and so is password and mcu's soldering.
if i use a nec key then key get activated and start car without problem.
have try 5 BE keys and all same result and 3 nec and 2 Motorola key and both work wihout problem.
