  • 20 Vote(s) - 3.1 Average
e200 2001 i change the cluster it cant ignition on and remote key not working
10
(10-28-2016, 12:25 AM)ryan4200 Wrote: What scan tools do you have? you could probably write the key your self depending on tools...
i use lunch i dont think it can write key
(10-28-2016, 02:20 AM)dominion1234 Wrote: Check the power in the steering lock and eis,may be power is missing in any of the components i mentioned. Hit the thanks bottom if i help.
i check them and all fine Sad
was the key working and ignition on before you changed cluster
Thanks given by: iyad.nasser
12
(10-28-2016, 09:34 AM)KriyenKPp Wrote: was the key working and ignition on before you changed cluster
yes the key was working fine and it work with the new cluster then i remove it to change a lamp after that the problme start
yes the key was working fine and it work with the new cluster then i remove it to change a lamp after that the problem start
first try replacing old cluster and see what happen, although i dont think so, but try. mb port say car start without cluster, try that because maybe cluster shorting down system, have to see first if cluster causing problem or you blown something when plugging cluster in
Thanks given by: iyad.nasser , bawarek
14
i try nothing changed and i check the ignition plugs and nno thing wrong Sad crazy cars
what the fault code mean
P1570 Fault in DAS to engine control module
what is DAS?
Fahrberechtigung System FBS
Thanks given by: bawarek
16
(10-28-2016, 01:50 PM)mb_port Wrote: Fahrberechtigung System FBS
what is that or where is it please?
YOU NEED DAS/XENTRY DIAGNOSTICS TO READ FAULT AND EREAS THEM IN THE DRIVING AUTHORIZATION OPTION.
All Mercedes Benz coding offline and SCN online.
Xentry PT & XDOS full installation.
18
problme fixed and it was the ignition i change it
Thanks given by: KriyenKPp , momosam
