ghades
Location OfflineJunior Member
18
Thanks Given: 54
Thanks Received: 65 (8 Posts)
43
15
11-06-2016, 09:14 AM
just bought a 1982 Mercedes 380sl but I need help the motor is stuck any suggestions??? also if I need to get the motor out is there a software that can show me all the parts? spec sheets of this car
thank you
ghades
18
Thanks Given: 54
43
15
11-06-2016, 11:38 AM
(This post was last modified: 11-06-2016, 11:59 AM by ghades.)
what I need is spec sheets (manual ,(detail) so I can se were the parts go if I decide to take the engine out.
the engine is stuck the last time the car moved or turned on was in 1995 so far I removed the spark plugs belts and fan and ill be adding wd40 in the heads to see if I can get the engine to turn
ps the engine has no water damage it was always inside a garage
this is what iam looking for thank you
"""MERCEDES 107 FACTORY SERVICE & REPAIR MANUAL 380SL 380SLC 450SL 450SLC 560SL""
ghades
18
Thanks Given: 54
43
15
maxbg thanks but the link does not work
453
Thanks Given: 444
Thanks Received: 1578 (376 Posts)
670
57
11-06-2016, 11:23 PM
(This post was last modified: 11-06-2016, 11:26 PM by efka.)
What do you have under the hood? engine 116?
2,095
Thanks Given: 14574
6,536
46
(11-06-2016, 10:30 PM)ghades Wrote: maxbg thanks but the link does not work
I'll see if I still have the disks when I get home next weekend if you can wait that long..
453
Thanks Given: 444
670
57
11-07-2016, 04:02 AM
(This post was last modified: 11-07-2016, 04:04 AM by efka.)
I have everything.... problem is that its all on microfiche (I mean MB original repair manuals-transferred to PDF). I need to know at least what kind of engine that 107 has.... then I can provide with correct info. But judging that its 8 cylinder - that particular year had problems with timing chains, otherwise they were bulletproof. I would just pull head covers and look inside..... most likely its just it. First one of these I got in 1991, then done couple after and then they ended as in "real Europe" Mercedes fixed them all at no cost if customer requested so.... Time goes by.... some things to remember....... (nothing to forget) And as for topic starter -give more info on the car I will give you what you need but normally these engines do not need any specific info - just old school with timing marks on sprockets and so. any engine mechanic can do these. Its like an old tractor engine just more bolts.
2,095
Thanks Given: 14574
6,536
46
They also like to strip the threads in the block when torquing the head bolts so we would drill the threads out and put in Time-Serts or Heli-Coils..
But yes, if its got a single row timing chain, it needs updating to the double row..
