help with 1982 Mercedes 380 sl - Printable Version
+---- Thread: help with 1982 Mercedes 380 sl (/Thread-help-with-1982-Mercedes-380-sl)
Pages: 1 2 3
help with 1982 Mercedes 380 sl - ghades - 11-06-2016
just bought a 1982 Mercedes 380sl but I need help the motor is stuck any suggestions??? also if I need to get the motor out is there a software that can show me all the parts? spec sheets of this car
thank you
RE: help with 1982 Mercedes 380 sl - Jan1980 - 11-06-2016
You want to have just part information ? You can register on www.service-and-parts.net and make official daimler EPC account (~ 50 Euro/year). You can find all your part numbers on this EPC.
Or do you want to have a guide, how to swap the engine ? U cannot use WIS on this old car, WIS is 1997 up. But should not be a problem to remove this engine.
What´s the problem with engine exactly ?
RE: help with 1982 Mercedes 380 sl - ghades - 11-06-2016
what I need is spec sheets (manual ,(detail) so I can se were the parts go if I decide to take the engine out.
the engine is stuck the last time the car moved or turned on was in 1995 so far I removed the spark plugs belts and fan and ill be adding wd40 in the heads to see if I can get the engine to turn
ps the engine has no water damage it was always inside a garage
this is what iam looking for thank you
"""MERCEDES 107 FACTORY SERVICE & REPAIR MANUAL 380SL 380SLC 450SL 450SLC 560SL""
RE: help with 1982 Mercedes 380 sl - maxbg - 11-06-2016
(11-06-2016, 11:38 AM)ghades Wrote: this is what iam looking for thank you
Look here http://mhhauto.com/Thread-Mercedes-Benz-W107-Workshop-Manual
maxbg thanks but the link does not work
RE: help with 1982 Mercedes 380 sl - efka - 11-06-2016
What do you have under the hood? engine 116?
RE: help with 1982 Mercedes 380 sl - Rocinante - 11-07-2016
(11-06-2016, 10:30 PM)ghades Wrote: maxbg thanks but the link does not work
I'll see if I still have the disks when I get home next weekend if you can wait that long..
RE: help with 1982 Mercedes 380 sl - efka - 11-07-2016
I have everything.... problem is that its all on microfiche (I mean MB original repair manuals-transferred to PDF). I need to know at least what kind of engine that 107 has.... then I can provide with correct info. But judging that its 8 cylinder - that particular year had problems with timing chains, otherwise they were bulletproof. I would just pull head covers and look inside..... most likely its just it. First one of these I got in 1991, then done couple after and then they ended as in "real Europe" Mercedes fixed them all at no cost if customer requested so.... Time goes by.... some things to remember....... (nothing to forget) And as for topic starter -give more info on the car I will give you what you need but normally these engines do not need any specific info - just old school with timing marks on sprockets and so. any engine mechanic can do these. Its like an old tractor engine just more bolts.
They also like to strip the threads in the block when torquing the head bolts so we would drill the threads out and put in Time-Serts or Heli-Coils..
But yes, if its got a single row timing chain, it needs updating to the double row..
