hello, I have here a problem with mb w204 c220 cdi 646.811 engine, and 5 speed automatic transmission EGS52
proble is that car cannot start with key,only directly from starter relay on the front SAm fuse box, and it cannot change gears
I have two permanent erroe in cdi ecu
22DD signal or transmission error from CP417 (TCU)
22E2 signal or transmission error from CP418 (electronic selector llever module)
in ESP unit
6106 no CAN message was received from combustion engine or transmission
and in kombi instrument U010087 communication with engine has malfunction message missing
I checked can bus wires continuity betwen engine ecu and CAN distributor and between egs52 ecu and selector lever module and they are ok
while measuring CAN bus voltages, CAN Hi ( blue white ) relative to gnd has 0,03 volts, and CAN Low ( blue) shows 1.9 volts relative to gnd)
I ttried to swap another egs unit and selector module but it remained the same
any suggestions?
in ESP unit
any suggestions?
, the problem is in the CAN H wire, you have a low voltage level there. The problem is probably somewhere in the transmission harness. Do you have Starfinder, WIS, EPC available?
