  • 26 Vote(s) - 3 Average
please help MB W164 key
Hi
please advise I have a car MB W164 CDI
MCU type: 9S12(1L85D,3L40K,4L40K,1L59W,0L01Y...)
VIN:WDC1641221A139571
ODO:62822,0
be is lost all key
after I have programmed a new key
the key turn in EZS withaut problem but engin turn not on!!!!
please can someone tell me what should I do ?
thanks
.zip
907E52D2.zip
13
7.24 KB
check with star
start actual value on ecu, atc,ism
Thanks given by: KriyenKPp , daxxer , ould
Before Key lost it was working?
If yes then simply bad key or bad data installed...
If not, Mr. mb_port asked you to see actual values Listen
Best regards.
[Image: mhhsig.gif]
Thanks given by: daxxer , Balyanchic , camaro , ould
